arlo pro can you use the magnetic mounts that come with the system outdoors
Hi. Is it possible to use the magnetic mounts that come with the system outside? All the videos/pictures I havw seen have more robust brackets for outside.
Yes you can but I would advise against doing that. The cameras, using the magnetic mount can be easily stolen or knocked down by animals or strong winds.
Brian
I have nearly all of my cameras outdoors on the magnetic mounts. Winds have never bothered them but if a bird or animal lands on them or can access them, all bets are off. FWIW, there's a post here from maybe a year or so ago showing how a racoon was unscrewing a camera from a threaded mount. Never say never...
My outside cams are on the half magnetic ball too... no issues.
Tho i do recommend a short tether to the camera ( 1/4-20 bolt to threaded hole ) tied around the mount bottom
If it does fall then, it won't go far.
IIRR, one lost their cam in the snow for a while due to very high winds, a squirrel stole one, bird landed on a cam and knocked off.... tether limits it's possible loss
All of mine are on magnetic mounts, many at face height too. I find the magnetic mounts that much easier to take the camera down for charging.
The cameras mounted on fences or walls are using the included half dome mounts. For under the eves attached to the soffits, I use the table/ceiling mount VMA1100
