  • 4 Replies
  • 1423 Views
CAUDE90
i can't access to the screen it is always said that the station is out and please check if there is internet  and electricity.
There are but it's doesnot work
JessicaP
Hey @CAUDE90,
What LED lights are showing on your Arlo Pro Base Station?
idark77
Yes, i have the same issue, today my Arlo Pro base station went offline and the internet led is OFF. Server Issue?
I also opened a new discussion for this issue.
JessicaP
Hey @idark77,
If you Arlo Pro Base Station Internet LED is off, then you might want to check if your internet/router is working properly. You can read here more of what the LED means: What do the LEDs on my Arlo or Arlo Pro base station mean?
idark77
Hey @JessicaP,
I think you had a server issue during last week ( Friday ) because my  internet/router was working properly and also all my other devices were working flawless. So I think that the problem was in the Netgear side.
After 12 hours I didn't change anything and It worked again ( all 3 Leds green ).
