When trying to view cameras on Win10 PC at https://arlo.netgear.com/#/login, Getting message:
This site can’t provide a secure connection
arlo.netgear.com uses an unsupported protocol.
ERR_SSL_VERSION_OR_CIPHER_MISMATCH
What is needed to correct?
You just need to use the correct URL (which is my.arlo.com).
Arlo split off from Netgear 5 years ago. Netgear kept arlo.netgear.com alive (redirecting it to my.arlo.com) as a convenience, but something must have changed on their side.
When I tried to log in to view my cameras this morning I got this message. It was working perfectly last night...
You should be using my.arlo.com. That won't give you that error.
Arlo split off from Netgear back in 2018.
Same problem here. It just stopped this morning.
Thank you Stephen that works great.
Thank you....worked for me.
Thank you. That solved the problem!
why is the web site not working. If it is eol I need a phone number to contact you.
Which web site? ARe you using my.arlo.com and not a Netgear one?
