Hi,
There is no Mic symbol on my app when I live stream the arlo pro camera from my phone. This happens on the laptop and when I am using my house wifi. Does anyone have any ideas?
Kind regards,
Yes.... there are quite a few threads re this.
It occurred from the last update on the 13th.
Un-install the app and re-install the app should fix it.
Uninstall/reinstall of app just worked for me.
Thank you, It solved! ![]()
