  • 15 Replies
  • 7884 Views
  • 4 Likes
  • 5 In Conversation
Dustin278
After numerous restarts my VMB4000r3 Base is stuck on 1.11.9.0_26520  -  should be
Arlo Base Station VMB3010/VMB4000 - 1.12.0.1_27940
  • Bug Fixes
JPC
Prodigy
Prodigy
Maybe a complete reset on the back of your Base and resync all cams can help? I know it's a PITA but sometimes when all things failed maybe it can help as a last option..
15 REPLIES 15
EKS
I’m having the same problem.
JoeCymru
Virtuoso
Virtuoso
Does it show updates available under devices settings? It certainly should. Sometimes a roll out just does not work for everyone. Other than that perhaps there is an account problem on the backend.
JPC
Prodigy
Prodigy
EKS
There is nothing listed under updates. I tried restarting the base and that didn’t help. So I may have to try a reset.
Dustin278
Looks like my last resort is to do a full reset then re-sync all my cameras.. what a PITA
Dustin278
Complete reset was the fix but what a pain!!
EKS
Thanks for the update! I’m going to give it a try. Any words of wisdom? Did you just push the rest button?
No. Remove everything from Settings, My Devices and start fresh, claiming the base and then syncing the camera.
EKS
Will I be able to sign back into my account without creating a new one? I’m on the Arlo Smart Premier Plan. Thanks so much.
The account itself isn't affected, just the hardware.
EKS
Thanks so much! I’m going to brave the waters tomorrow. I’ll check back in with the results.
Dustin278
Yeah I reset the base using a paperclip and holding for about 10 seconds - waited a few minutes for base to boot back up and then started adding all my camera's + doorbell via Arlo app.. Up and down ladders to get all my cameras.
EKS
I’m not looking forward to that!
It's a pain but the end result can be worth it. One tip - if you have a second person to help, position one at the base to press the sync button and the second going to each camera. Depending on the signal strength, the first person can briefly press the base sync button (don't hold it) and let the second person know to press the camera sync button with the camera in place. I do this all the time with 100% success but can't guarantee that level for everyone else. It solves the need to take the camera down to sync and then have to reposition it.
YMMV.
EKS
Reset my base added my cameras and everything updated as it should. Thanks everyone for your help!
