Is the Cloud Storage for Basic still 1G? and if i happen to use up all my cloud storage in 2 days what happen? will it automatically delete older files?
I notice my arlo suddenly doesnt record even when motion is set at 100, is this an indication my cloud storage is full? i didnt get any notification and cant seem to find any place indicating my available space remaining.
The "suits" , yes , still list the basic level of storage at 1GB, but it has not been enforced for almost 2 yrs now
I wouldn't worry about that... Also, if you have the PRO model, you can use a speed stick of 5-10GB and have plenty of storage backup ( and it can be set to overwrite the old fiiles, IIRR )
If you cameras aren't recording at all ( and were in past ), I would check all you settings. Make sure AFTER arming the running man is black for each camera ( in live view ) ...if not black no recordings will occur.
If they are set properly, then the first thing to do is power button reboot the base
