  • 2 Replies
  • 3761 Views
Pucksterpete
Hello, What is the difference between arlo solar panels VMA4600 and VMA5600? Thanks
4600 is for the Pro/Go models while the 5600 is for the Ultra
brh
@Pucksterpete
The physical differences are that the VMA4600 has a detachable cord that has Micro USB plugs on both ends with rubber grommets built in to prevent moisture entering the unit and damaging it. The VMA5600 has a cord that is not detachable from the panel and a magnetic connector on the camera end that is the new way of attaching power cables to the Ultra cameras. They are not interchangeable.
Brian
