Video Playback not working on iOS
  • 12 Replies
  • 6043 Views
cturbitt
Hello!
I have an IPhone XR and Arlo Pro cameras, for 2 days now I haven’t been able to watch any video playback. If I save the video to my photos, I can watch it but for some reason it just sits on the buffering wheel and never plays off the app.
This is getting annoying as I’d like to monitor my home when I’m at work.
12 REPLIES 12
ShayneS
Hi @cturbitt
Does this occur on mobile data & Wifi?
May I ask which troubleshooting steps you have performed so far? I don't want to suggest any prior methods you have previously performed.
cturbitt
Thanks for reaching out, it doesn’t work on either WiFi or using cellular data. It only works if I save the video and playback under my photos.
cturbitt
Also I have tried to turn off each camera and restart, restart my wifi, try different WiFi networks
ShayneS
Which version of iOS are you using as well as the Arlo app?
cturbitt
2.17 version for Arlo - no update on the App Store
iOS 13.4.1
ShayneS
Is this with recorded videos or is this live streaming?
cturbitt
Just recordings. I can view live stream without issue.
ShayneS
@cturbitt
Thank you for the info. Is this all your recordings in the library or a select few? Are they recordings from motion detected or manually started?
cturbitt
None of the recordings are working for playback in all 3 cameras I have. They all worked before, then all stopped. They are all recordings from motion detection.
ShayneS
Have you tried to reboot the cameras by removing > Re-inserting the batteries?
cturbitt
Yes, each camera was restarted by taking out the battery and putting it back in. We also attempted to resync one of the cameras and nothing changed.
ShayneS
I see, Thank you for all the detailed information. To further investigate this issue, Please contact the Support Team. You will find several options for contacting support in the provided link. Arlo Tech Support
