Video Playback not working on iOS
Hello!
I have an IPhone XR and Arlo Pro cameras, for 2 days now I haven’t been able to watch any video playback. If I save the video to my photos, I can watch it but for some reason it just sits on the buffering wheel and never plays off the app.
This is getting annoying as I’d like to monitor my home when I’m at work.
Hi @cturbitt
Does this occur on mobile data & Wifi?
May I ask which troubleshooting steps you have performed so far? I don't want to suggest any prior methods you have previously performed.
Which version of iOS are you using as well as the Arlo app?
iOS 13.4.1
Is this with recorded videos or is this live streaming?
Thank you for the info. Is this all your recordings in the library or a select few? Are they recordings from motion detected or manually started?
Have you tried to reboot the cameras by removing > Re-inserting the batteries?
I see, Thank you for all the detailed information. To further investigate this issue, Please contact the Support Team. You will find several options for contacting support in the provided link. Arlo Tech Support
