Is there a setting or feature that limits the zoom magnification? Can this be adjusted?
Thank you in advance for any insight or advice.
I see no difference just tesing on the web browser.... are you using a phone... ios/ android?
I am using the iOS Arlo app.
Yes... just tested on an Ipad... it doe NOT zoom as big as it did. It may be a product of the new compatability for the Arlo Baby
This is not user adjustable
Thank you. I do see that a new version of the iOS app was published on May 2. You are likely correct that it has something to do with this update for the nursery cam. Hopefully Netgear fixes this on the next update.
I have escalated this topic for review. I will post an update when I have more information.
I am facing the same issue with the Arlo iPhone App. I have the Arlo Pro Wire Free Cameras. Do we have any updates on this yet?
Hi James, I too have experienced this problem. Can ARLO please fix this feature? I need this function to work up to 8X for safety/security reasons (need to view and record ongoing suspicious criminal activity). Can only zoom to 2X. Please help, the camera does me no good in it's present capacity.
