For several months the base has been rebooting/not recording. It is now rebooting every five minutes or so. I performed a reset three weeks ago and it worked for a week. Now nothing but rebooting.
5 REPLIES 5
Not sure why you would wait so long - use the Contact Support link at the bottom here to use your 1 year warranty.
Ummm... Several years out of warranty. The problems arrived recently. Thanks?
Time to buy a new base.
Agreed. Now it's time to decide which brand to go with. Thanks!
Brand or Arlo model? Since you have the cameras, a new base would be cheaper. I would suggest the VMB4540 so have local recordings if you wish and use the app to view them. It would also set you up for newer devices that might not work on older models (or at least miss features such as the local recordings/use of the app).
