Is this common for them to be good for a week??
No this is not common. I have some still running after a few months, one by my front door which gets a fair amount of traffic. Mine are set to the highest resolution. Where are cameras mounted (how far from the base) and how much traffic a day do they see IE. how many minutes of recordings? Specs are based on 5 minutes of recordings per day (30x10s recordings).
What are your record times set to? Default is 10s.
Let's check all of those first before trying a reset and re-install.
I have a battery installed on 12-16 and it shoots 7-9 15sec vids a day sitting at 53% , so to drain in one week isn't normal.
As to the back camera , the sugnal could be weak, draining the battery more...check the signal level on the little wifi icon or in settings
The total number of minutes of recording and live view should be <5 minutes per day to maximize battery life. Are you doing this? If not, what kinds of totals are you seeing? The connection to the base is also important - weak signal or interference leads to shorter battery life due to the struggle to maintain the connection.
"going on app to check what's going on" If you are using live view to do this, do you remember to hit the pause button to switch off live view once you are done looking?
Switching tabs or leaving the app _should_ cause live view to stop. No guarantees, though.
