Hello Arlo Community,
I'm based in Singapore and I intend to purchase an Arlo Q and Arlo Pro security camera set from Amazon USA (cheaper than getting them locally).
My question is:
- Will the power adapter for the base station (Arlo and Arlo Pro) and Arlo Q as well as the battery charger work here in Singapore?
The input rating for Singapore is 220-240V.
Thanks.
The PRO adapter here in US are 100-240 vac input... 50-60hz at .3a
But the actual output for the Pro camera is a standard 5v usb and 9v ( qualcomm dual voltage for charging )
The Q ac adapter is also 100-240v listed but only puts out the 5v usb
Thanks for the info! Which means it's safe for me to import the Arlo products to Singapore from USA.
All I need is an extra adapter or two to adapt the two-pronged power plug into the local wall socket here.
Hi TomMac
I read from other post that the adapter for Arlo Pro base is 120v only, can you confirm that the adapter is in fact 100-240v? I am quite confused now.
thanks,
Francis
