when I push the talk button on my iphone to talk it does work however it turns the sound off on the camera and the only way to get audio back is to stop it and turn it back on.
A new version of the iOS app that resolves this issue is now available. Please make sure you update to the latest version from the App Store. See here for details: Release Notes - iOS App 2.4.1 - 24th May 2017
Weird. Try power cycling the base and pop the battery out of the camera to reset it.
I have the same issue. Basically, after I click on the microphone to talk to the camer. The sound can be hear on the camera, but no sound come back from the camer to my phone, and you cannot get out of that mode unless you stop the live view and come back in
I have escalated this topic to engineering for review. I will provide an update when I have more information.
The mic icon does not appear on my live screen. My iphone Arlo app uis updated to version 2.4.2.
I did have it when i installed my systemin June (2017), but when I went to use it the other day I can only hear the cameras and NO mic icon is there anymore.
Please help.
Jimbo19422
The mircophone will not work even though it's turned on! No updates are needed. That's why I bought this model. What now!?
Having the same issue. app is up-to-date, firmwares up-to-date.
When trying to use micrphone within iOS app the speaker is muted and does not return until you stop the feed and restart it. Not a good bug considering connecting in the first place takes a few seconds.
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
