  • 1 Reply
  • 1763 Views
Bekki624
I have tried to reset my time zone & restarted my system & the time is off. Notification comes through at 10:22 PM, but when I look at it says 8:22 PM. I've changed the time saved & went back & changed it back & saved. I even restarted my stem & it still doesn't show correct time & I can't review the recordings until 2 hours after actual recording takes place
ShayneS
Bekki624,
Have you tried to change the Timezone in the Arlo Mobile App or the web portal?
