The system can't be turn on and off according to personal scheduled program.
  • 9 Replies
  • 4049 Views
  • 2 Likes
Ssu-Wei
After the last update (several days ago), my arlo system can't be turn on and off according to the oraginal scheduled programs. Can anyone help me to fix this problem?
Ssu-Wei
It works now, and I did nothing. Maybe just some errors in system temporarily. Anyway, thank you for help, guys.
9 REPLIES 9
steve_t
Master Master
Another user reported that somehow, during their last update, their base station's time zone got changed and that's why their schedule stopped working. Please check that by going into Settings > My devices > "Name of your base station" and check you have it set for the correct time zone
Ssu-Wei
Thank you for reply. The time zone for my base station is correct after checking it. I also reset the time zone, but the scheduled program still can't work.
steve_t
Master Master
Do the modes in your schedule work OK if you activate them directly?
Ssu-Wei
No. The schedule can't work even though I activate the system directly.
steve_t
Master Master
No, I mean the modes that you're scheduling eg ARMED or a custom mode. Do they work outside of the schedule mode? eg set your system to ARMED. Does it work?
Ssu-Wei
Yes, I still can turn on and off the system manually.
watchdog99
Luminary
Luminary
you will probably have to reset the schedule.
steve_t
Master Master
Agree. Redo your schedule from scratch and see how you get on
Ssu-Wei
