Telus Smart Hub
  • 2 Replies
  • 3969 Views
CanadianKodiak
I'm using a Telus Smart Hub for internet access and it doesn't require a router. How can I hook up my Arlo security system to use Telus wifi provided by the Telus Smart Hub?
First of all, it is a cloud service, and the data usage could be expensive.  You also should measure the upload speed.
All Arlo bases connect with ethernet.  So you need to get a WiFi extender that has an ethernet port.  Then pair the extender with your Telus Smart Hub.
CanadianKodiak
Thank you. I purchased an extender and it worked fantastically.
