I'm using a Telus Smart Hub for internet access and it doesn't require a router. How can I hook up my Arlo security system to use Telus wifi provided by the Telus Smart Hub?
Message 1 of 3
3,998
First of all, it is a cloud service, and the data usage could be expensive. You also should measure the upload speed.
All Arlo bases connect with ethernet. So you need to get a WiFi extender that has an ethernet port. Then pair the extender with your Telus Smart Hub.
Thank you. I purchased an extender and it worked fantastically.
Message 3 of 3
3,917
