I purchased two Arlo Pro cameras to add to my other six Arlo (non-pro) camera system. The immediate draw, for me, was the two-way communication. I installed both of the Pro's and the picture and video quality are excellent. The sound from the internal mic on the cam is pretty good.
The problem is that when you attempt to speak to someone at the Arlo Pro cam, they can barely hear me. They have to be really straining to listen. The volume is up to the max on my app. The Pro cameras are installed outside, but in the entrances of my home and the external environment is typically quiet.
I need some real solutions for this problem. I've logged a support case and they have not offered any real solutions. Rather, they pretend that this is not a KNOWN Issue with the Arlo Pro cameras.
I'm open to any suggestions. Otherwise, I'll return my Pro's and hope that Netgear gets this resolved in the future.
AJMRN30,
Do you notice the same behavior when using the web client on a computer as suggested above or does this only occur from the mobile app?
I am having the same problem. Whether I use the Arlo software and speak from my Galaxy smartphone or from my laptop, a person standing within a few feet of my Arlo Pro camera can barely hear me, even if I am speaking in a very loud voice. I know that this has been an ongoing issue and was supposedly "solved" in the community forum by a firmware update, but I have firmware version 1.090.0.0_9945, which I am assuming was issued after the firmware update that supposedly solved this audio problem. Am I using the most recent version? Why can't people standing within feet of my Arlo Pro camera barely hear me?
Birl,
Very low on your end indicates the volume is down on the device you are using. Check your device settings and increase the speaker volume.
