  • 1 Reply
  • 1597 Views
BrianDish
I would like to know if a static IP can be set on the VMB3500 base-station, and if so could someone please show the directions to do so.
You can't configure the network connection on the hub.
What you can do is reserve an IP address for it in your router.  This feature is available in most routers - sometimes called
  • Address Reservation
  • Mac Address Reservation
  • ARP binding
depending on your router.  This will tell the router to assign a persistent IP address to the base via DHCP.
Check the router manual, and see if you can find the feature there.
