Selecting Geofencing disarms arlo system
I am using the Arlo Android app version 2.7.8_25585
I have a custom mode that dictates that some cameras will be on( motion activated) and others off
I have scheduled that during the from 8am to 8pm the phone will be in this custom mode.
From 8pm to 8am the schedule is set to alarmed.
I use geofencing home is set to schedule and away is set to alarm.
When I log in to the app and set to geofencing it says geofencing enabled. However, none of the cameras respond to motion.
I log back into the app and the mode is set to disarmed despite still have a notification from arlo saying geofencing is enabled.
I click to change the mode and when I get to the mode select screen it says geofencing is chosen.
Hi @Error720 ,
We are investigating a Goefencing issue related to Schedule.
Does Geofencing work for you if you set Home to a Mode, like Armed?
Thanks for confirming, @Error720
