Power button reboot the base and see if that helps ( off then on , let come back online about 2 mins )
I am having the same issue. My Monday schedule I had set from midnight to 7am doesn't appear on the app, nor do my cameras detect any motion. When I log onto the arlo website the Monday schedule is there; however, like I said, the cameras don't seem to be actively detecting motion during that time. If I turn them on without using the schedule they seem to work (not always though; during the last couple weeks they've been hit and miss as far as detecting motion and/or recording videos when they detected motion). I have tried rebooting the base station and deleting and reinstalling the app on my phone.
Having the same exact problem here as well. Only involves Mondays. You can click the dot for Monday, but as soon as you hit done, nothing is scheduled for Monday and when you try again, the dot for Monday is blank. A power cycle did not fix the problem.
It seems, that for Monday only, if the schedule starts at 12:00am then it gets deleted. If you start it at 12:01am or any other time, it is saved for monday. Seems like a bug to me.
I haven't tried too many things since the scheduling changed somewhat but I note that now the ending time defaults to 12:00AM instead of the previous 11:59PM. I have always used 11:59PM as my end time and 12:00AM as the start time and that seems to work properly now. Try that out.
I thanks for the tip on starting the schedule for Monday’s at 12:01 versus midnight. That did work.
Schedule and geofence still faulty here. Android latest update installed. All issues began after the application update to cater for lights. I do not have any arlolighArl by the way.
I am having the same issue. I've deleted all my schedules that had been working for over a year and started over. Still no luck. Nothing seems to be recording between midnight and 8am for me even though the schedule shows it active. I have basically abandoned the scheduler which is a major issue. Hopefully they will get this fixed soon.
Try using a browser to set up the schedule - works better for me.
