Recently (w/in past week) I noticed I'm unable to log into "My Arlo" website while using Safari web browser. The website only displays the arlo bird, and no login option. Anyone else have this problem, or know of a solution?
Tried Google Chrome and it works fine.
Having the same problem here as everyone else who has posted. Can't log onto Arlo with Safari 9.1.2. Flash is up to date.
AFAIK, logging in has nothing to do with Flash. The site just needs https access to arlo.netgear.com. Have you tried another browser? Does the app work ok when on the same network?
I was having the same problem as everyone else on my laptop (Safari 9.1), but the login worked fine on my iMac (Version 11.0.1) and on Explorer. Deleting Caches, updating Flash, and restarting didn't work, but then I updated the whole Operating System to High Sierra, which automatically updated Safari to Version 11.0.1, and now the login appears and works fine! Hope this helps.
I downloaded Google Chrome
Arlo.netgear.com does work with Chrome on my older macs running OSX 10.9.5.
Chrome is subjectively faster than Safari, but it is such a hassle to switch as one also need to port all the passwords and web history across.
Whilst using Chrome partly resolve the issue, it is still very disappointing that Netgear cannot be bothered to make arlo work with older versions of Safari. Not everyone can update to the lastest MacOS.
I understand the frustration but there's NO company that keeps updating new software with old equipment and OSes. There's always a cutoff at some point and workarounds have to be found.
Not familiar with how Chrome works on a Mac but check the settings - there may be a way to import your Safari "stuff" into Chrome. I see Settings, People, Import Bookmarks and Settings that may do this for you.
I cannot log in to Arlo site via Safari on Macbook Pro. Problem first occurred several days ago.
Have you tried a different browser?
"You may be logged into NETGEAR Arlo in a different browser tab. Please close the tab before proceeding. You can also try to restart your browser or delete cookies from your browser before trying to login again."
this is what I get when I try to login. tried safari, chrome, etc - same error. no other tabs open. basically can not access arlo site from computer now (used to work just a week ago). very dissapointing that the only suggested solution is "use other browser" - this is not a solution.
I don't use Safari but this is the message from JamesC's post to get it to work with Chrome:
For those experiencing an issue logging in, if using google Chrome try pasting this in your url bar and then click "Remove All":
chrome://settings/cookies/detail?site=arlo.netgear.com
If that doesn't work, clear your browsing history in Chrome.
My guess is that you need to do the same for Safari
Brian
I'm also getting from about a week ago:
'You may be logged into NETGEAR Arlo in a different browser tab. Please close the tab before proceeding. You can also try to restart your browser or delete cookies from your browser before trying to login again.'
Can access via iphone but not from a variety of web browsers. Very odd.
Don't understand why they hide their head in the sand about this issue. Restarted browser, cleared cookies, nothing helps. Clearly the website is broken somehow as it happens for many people.
I haven't been able to login to arlo for the last week or so. It kept complaining that I had to clear my browser history. After several attempts as well as rebooting my system nothing worked. I noticed that this started happening about 1-2 weeks after I switched from using Edge to Chrome to get my mic to work. I finally got it working my following JamesC's recommendations - 1. Paste this in URL (chrome) browser, chrome://settings/cookies/detail?site=arlo.netgear.com, and click on Remove All. 2. I aslo went to my browser Advance settings and allowed Adobe flash to always run. I removed all my cookies from IE, Edge and Chrome, rebooted and then it started working again. Phew! Thanks JamesC for the help.
I also like to add that when this issue started happening and I couldn't monitor my cameras, I was at least counting on that I could check my email account for any alerts but somehow this also stopped working. I hope that the Arlo team can really look into this so that at least we can continue to receive alerts when we're unable to login. I honestly thought I got hacked and started to turn off my cameras.
Same for me in Chrome for about a week. Any fix for it?
I'm getting the same message in Safari. The site works fine in Firefox.
Safari has the latest java and it's specifically turned on for the arlo page.
I cleared cookies, restarted browser, restarted computer. Same message.
OS X 10.12.6
Safari 11.0.3
Firefox 59.0.1
I am having the same problem with Firefox. Need help also.
I tried Chrome and others have tried Firefox??? Still same problem?
Works fine on cell/i-phone but no connection with desktop?
Have tried other browsers and still the same problem.
Anyone else seen this message:
I am using Internet Explorer, Chrome, and Edge web browsers.
I am having the same problem, I am using Firefox web browser and have tried Chrome and Interner Explorer with the same results. I have turned off my Kaspersky anti virus and no help. Not sure what Netgear did to suddenly change.
Please let me know if you can find a fix.
I get a message that reads: "You may be logged into NETGEAR Arlo in a different browser tab. Please close the tab before proceeding. You can also try to restart your browser or delete cookies from your browser before trying to login again." I used to operate Arlo through my computer but now I cannot. I looked at the bottom of my Arlo base and it smelled like burnt wiring. Could something have burned inside the module?
While anything is possible, that's not the root of the "different tab" issue. Have you cleared the Arlo cookies from your browser?
