I just purchased the Arlo Pro System a few weeks ago and It appears that I had left the charger and charging cable in the box when I discarded the packaging. The replacement chargers are saying coming soon on the Australian webstore. No other micro USB cables and wall power supplies will work and say that I need to use an arlo. Any idea where I can get the replacement charger or an alternative? My arlo batteries have run out, please help!
Any quality cable (not the cheap ones with smaller gauge wires) should work fine as long as the microUSB connector fits - a bit of trimming might be needed. For the charger, a quality (there's a theme here) one which support Qualcomm Quick Charge capability should work. It will provide both 5v and 9v outputs of at least 1.5 amps. Try an Amazon of Google search for "usb quick charger".
Thankyou for your help. This worked well
