Is it possible to delete more than one video at a time?
You don't say what device, but yes on all 3 ..... All per day only
pc , you go to library hit select the choose ones you want then delete
iOS app, works like pc
Android, you go to library the hold on one picture clip ( IIRR,it turns color) then if you look to the top of pic clips you'll see a grid type box appear, one allows multi picks
