If you used the same User/password then the videos may appear in your Library untill they expire and get deleted or you can manually remove them
Also you can try and power button reboot the base
I am having this issue too. Removed a few cameras from my account and made sure there are no saved videos from those old cameras and they still show up in the camera list on the app when I try to search for videos. Frustrating. Any way to solve this?
No.. there is no fix. NETGEAR doesn't care... that's the bottom line!
I spent a long time with the NETGEAR team, and although they eventually understood the problem after about 6 rounds of messages back and forth, they closed my tocket and said, "issue resolved". It was amazing when support asked me for detail that I had already written in the original ticket. I replied to NETGEAR again and ask ed them to tell me what was resolved, because they did absolutely nothing. They, of course had no answer. Their customer support team is absolutely useless, and once NETGEAR has your money, they don't care either way. The customer support team couldn't even come-up with the idea to open a ticket to correct the problem on the next release of their firmware. I suggested to the last representative I spoke with, that they put this issue into their next bug fix, but again their customer support team is absolutely useless. In the end I wasted a lot of my time and NETGEAR support did nothing but waste their time because they had no intention of fixing anything.
I can’t view the old camera, but it’s annoying to see it as a phantom device in the library still. 🤨
iPh7+ iOS 11.3
