- 2
Folks, it looks like the feature we were asking for is finally here!
I've just went to adjust the recording length and found a new setting there - record until activity stops (300 sec max).
Good job, Netgear!
I wouldn't say this was a "prime factor" in my purchase, but an expected feature. The cheaper less connected cameras I previously used had this built in.
If there is logic to know when movement starts, it's simple enough to use same to know when movement stops. With the 15/30-second delay in recording "again" I often miss major moments I know it should capture.
Thankfully nothing bad, but when I know my kids came into the house or exited and I get a 3 second clip of that happening (b/c delayed start, etc.), had they been an intruder, I know the recording wouldn't have been useful.
I trust they're actively working on this and it is a high priority for them. Honestly, my cameras are great for watching my dog and seeing when my kids and helpers come and go. But honestly, if I were robbed, I do not know how valuable any of the footage would be the way it starts/stops recording.
PittCaleb
Sorry to hear about this. This is probably little consolation, but Arlo tech support told me that if you have two cameras aimed at the same spot, one set up to watch for motion and the second one to record the event (if camera 1 sees motion, record with camera 2), the reset time goes down from 30 seconds to 5-10 seconds. I tested this and found it to be true. Of course, this gets very expensive very fast, and is too late for you in this instance. But I thought I would mention it in case it helps anyone.
Hello,
Is there any update about this feature?
I was about to buy a 4 cameras kit but when I discovered the limitation about the fixed length recording I reconsidered the purchase.
It seems a too strict constraint: I would end up in having dozen of false positive 15-120 seconds videos and possibly missing frames I need due to the cut after the fixed duration.
I am now using Canary (I know it is a powered camera, so not power constrained), but the beauty is that I have videos that last exactly the duration of the event (from a couple of seconds to 30+ minutes).
Thanks,
ReX
So in your setting you have a minimum recording time of 16 seconds (why not 15?). Is it correct to say that the camera records also the 16 seconds following the last detected movement?
What is the distance of motion detection? Can you specify areas?
Distance is the same as always with people being on the order of 20 feet max. And, no, zones are not part of the wireless camera architecture.
E.g. the camera detects motion (at time 0) and triggers recording. The motion lasts till second 40. Will the recording end at 40 + 10 or 0 + 10 (assuming 10 is the value you configured as "delay to stop recording")?
Nope. No settings on this at all - it's up to the system.
I've seen a couple of video on YouTube and they were showing 15 seconds recording, even if there was still motion in front of the camera. So either the users selected fixed length video or the camera is not able to record in a single video the totally of the event.
Can you set it?
- 2
