- 2
This article, while discussing the Ultra, says that clould storage for regular users is only 3 days. While this is only one article to say this, and may be inaccurate, I did get a pop up this morning when opening my recordings hounding me to upgrade to a paid plan.
https://www.techhive.com/article/3325214/security-cameras/arlo-unveils-its-ultra-4k-smart-home-secur...
Any thoughts on this?
Ah. Despite having auto updates turned on on my iPhone, just found a buried nag to upate to iOS 12.1.2. Maybe that is my problem.
Updated iOS and reinstalled the Arlo app. Same result: Only one camera is going into the Library. The others can be watched live, but are not saved. I will just pay for the lowest level of cloud storage. Given that the Basic subscription is a legacy feature that never generated any revenue by itself and is no longer offered, it will break every once in a while as Arlo's software is updated over the years.
And you're sure a filter isn't set in the library?
Never used the "Filter" feature. Found the feature and it says "any."
Why are there no comments here from Arlo?
Thought this thread might be of interest to this group as it's had a (very quick) response from Netgear on exactly this topic.
https://community.arlo.com/t5/Arlo/Where-is-my-Basic-plan-gone/m-p/1672264/highlight/true#M63092
- 2
