Both mine and my wife’s iPhones ( XS and XR running IOS 12.4.1 ) are showing as disabled in the new Arlo app. Location services are set to always on and both devices are showing in the enabled devices screen in geofencing. Prior to loading the new app, they had suddenly began to show as unavailable in the legacy app. Tried just about everything except wiping the base station and starting from scratch. The address is correct in geofencing and again verified location services are always on in the Arlo app in location services and under settings. I do have Home Kit enabled but the issue began well before it was set up. At this point my cameras have to be manually armed and disarmed. Very frustrating, have no idea where to go from here. Any help would be greatly appreciated.
Hi @NoGeo702
Base station VMB5000r4
iPhoneX on IOS 13.1
Everything is configured correctly. Now even though I enable a device, the device screen shows the device as "disabled" to the right of the screen, even though the device is checked. Happened when I upgraded the Arlo app 2.9.1 (1134). I am unable to enable any device. They all get marked "disabled".
Spent an hour or so on chat with customer support trying to get this fixed with no resolution.
Case # is 41156400
Hopefully this will get fixed soon,
Finally figured out that the devices being marked as "disabled" didn't mean that the device was disabled but that geofencing was disabled. Once I enabled geofencing the devices showed the correct zone. Closing case.
How do you mean “geofencing was disabled”?
Do you mean simply switching to geofencing mode? When I do this both our devices still show as “disabled” and geofencing doesn’t work. So frustrating! Had hoped the years of bugs would perhaps be gone in new version but I guess not!
Just enabling Geofencing did not work for me, I had to reset the hub and remove and reinstall the app. Then the phones returned to either in or out of zone. However, when that happened, my cameras no longer sense motion. They are on the network and can be viewed live but won’t or can’t detect motion. All settings are correct. I am going to try and remove them, reset them, and then reinstall them onto the hub. If that does not work I am going to blow it up and start from scratch.
Very frustrated with the amount of time spent in constant system repair.
I’ve had years of troubleshooting and frustration. Definitely wouldn’t have bought the system if I had known how buggy it was.
Here is what finally worked for me with reference to the cameras not detecting motion. This sequence worked. Remove the camera battery and delete the camera from the app. Power cycle the hub then add the camera back into the system. If I did not power cycle the hub, it would not add the camera. For the first time in a month, the entire system is functioning.
Geofencing is broken on my system as of last night. Both devices all of the sudden say "disabled" in the geofencing > enabled mobile devices menu. Geofencing had been working fine for a few months. Anybody have ideas about what's going on?
What mobile device are you using? Also, what version of the app?
Version = 2.10 (1478)
Device = iPhone SE, iOS version 13.1.3
Thanks.
Quite a few people are reporting issues with scheduled modes today, and that perhaps also spills over to Geofencing.
There's nothing on status.arlo.com (at least not yet).
