Hello. We put a camera outdoors on our front porch and during the day it only detects motion when it should (when someone delivers mail for example). But at night it detects motion every single minute of every hour. This is causing the batteries to run down and captures tons of uncessary footage etc. Can someone tell me how to troubleshoot this? Thanks!
New camera/base station firmware has been released resolving this issue. Please be sure your system is up to date with the latest firmware. See here: Release Notes
Contact support. Most likely you'll get a replacement, you're not the only one with this problem.
Ikram,
I would like to assist you with this issue. I will reach out to you in a private message to collect more information.
manofice,
Sorry the late response, engineering is still currently reviewing this topic.
If you are experiencing this issue, can you confirm you still see the same behavior when audio is disabled for the camera?
Consider disabling or reducing audio sensitivity and test to see if you get the same results:
How do I change the audio sensitivity on my Arlo camera?
Log in to your Arlo account and navigate to Settings > My Devices > select the desired camera > Audio Settings > toggle off speaker and microphone
I am having similar issues with two of my Pro cameras. Once night falls, I get constant alerts. They are postioned on the north and south sides of my house and I have neighbors on both sides approximately 7 feet from both sides of my home. I have a total of 4 pro cams. All outside. The one on my back porch facing the yard works perfectly as does the one further out by the garage. It's only the two cams between the neighbors that are triggering like nuts at night.
I have adjusted the sensitivity on both troubled cams to no avail. Could the proximity of the other homes with lights turning on/off or heat be causing these false alarms?
Best regards,
Pete
I suppose it's possible but I haven't had those things set my cameras off. What fixed my repeat recordings was to have the camerasd replaced.
scbatech
@scbatech First I did a reset of the base station which is a bit of a chore as the cameras needed to be joined again to the base station. I had better success adjusting the cameras a bit more downward and away from the side of the house. False alarms went down dramatically but it was a bit hit or miss (up the ladder/down the ladder, rinse/repeat). I did get a ton of false alarms last night but I attribute that to the snow blast we received.
I think the angle of the camera plays a huge role in false triggers and I had to choose the most important thing (like a side door) and skip trying to capture a larger scene. Hope this helps; I was ready to throw in the towel at one point but I am satisfied now.
As mentioned many times, contact support and open a case. Use the Contact Support link at the bottom here.
Thank you for updating with this info.
I have been experiencing the same with one of my cameras.
