Why aren't both of my two cameras listed in the MODE section? Only one camera is listed.
Everything shows that my second camera is working properly and I can make adjustments to it under SETTINGS, but it doesn't even show up when I click on the MODE tab. So, I can't ARM it!
While I was waiting for a reply, and had tried everything else, I finally did what computer repair guys always tell everybody: "Turn it off and then turn it on". So, I clicked on RESTART base, waited for it to finish, synced both cameras again and the problem was solved!
Thanks, Guru, for your reply.
Only the Q cameras show up directly in the Mode tab. Otherwise, the base(s) will be there. Select a base and the modes for that base will appear.
