I am not getting notification for motion detected for about 45 seconds-minute after they occur. I used to get them almost immediately, but for the past few weeks it has been lagging. Is anyone else having this issue or know of a way to fix it?
Are you using Smart? The post-processing needed to identify the object may be causing the slight delay.
Hi willijom337,
Do the push notifications happen to be coming in late intermittently, or has it been consistent? Have you tried to reboot your Base Station?
