No sound when playing back a video from my iPhone. Tried reinstalling and have the latest updates.
I have no sound when playing back a video from my iPhone.
I have the lasted updates.
I’ve also deleted and re installed the program. It’s still not working???
Hi Gunnarv5,
Does this happen when you're on your WiFi and/or cellular data? What iPhone are you using and what iOS verison are you running?
Have you tried to reboot your iPhone to see if that helps?
