No motion after recharge.
  • 6 Replies
  • 2852 Views
DrexelLake
My motion stopped working after recharging the battery.  I turned the camera off.  Recharged, placed it back and turned it back on.  I made no changes.  As far as I can tell the settings look normal.
6 REPLIES 6
Can you live view and manually record? is the running man for the camera in the Devices tab black or gray?
DrexelLake
Everything seems to be working again. Except that for some reason the area of the sensor is not accurate.  I have it pointed down my driveway to the street and have it pointed down enough so that cars going by don't trigger it.  People can walk all the way down the driveway to my house about 20 feet, but all that shows up is them walking out of the picture towards my front door.  No video until they're leaving the area of coverage.  Crazy.
Might be worth removing the camera from Settings, My Deevices and resync.
DrexelLake
I've tried that.  I also suspected the battery when new.  I recharged to 100% and it's already down to 94% in about 36 hours with only 25 events.  It definitely drains faster than my other cameras. Maybe I need to return it.
DrexelLake,
You could try to swap locations with one of your other cameras to see if a different camera behaves the same way in that location. It could be a problem at the cameras position.
DrexelLake
I'm thinking fo doing that, but I'm bed ridden for a while.  Just had a knee replaced. My guess is it's dying faster because it farther from the base. Using more power to pick up the wifi signal.
