Beginning on March 14, 2026, I observed that the live stream functionality on Pro 6th Gen 2K cameras stopped working, displaying a continuous loading (spinning) indicator. The issue appears to be isolated to the web application when accessed via a PC browser. Live streaming continues to function as expected on Android mobile devices.
I have completed all standard and recommended troubleshooting steps, including clearing browser cache, testing multiple browsers, power‑cycling the cameras by removing batteries, and re‑syncing the devices to the Wi‑Fi network (2 Gbps symmetrical fiber‑optic connection). These actions did not resolve the issue.
The problem was reported to Support and subsequently escalated to higher‑tier support, with a support ticket opened for investigation. As of March 19, 2026, there has been no update or resolution provided.
Best answers
You should now see improvement with the behavior you were seeing. Can you please let me know if you notice the difference throughout the day?
Thank you for reaching out and providing this information. I have reached out to our development team to look into this further. I will update you as soon as possible.
@dfking can you please provide a screen recording of what you are seeing. You can send this via dm, you send a dm by clicking on the envelope icon on the top right of the forum page.
No change - still is not working.
@BubbaScott can you please provide a screen recording of what you are seeing. You can send this via dm, you send a dm by clicking on the envelope icon on the top right of the forum page.
I was going to record the issue this morning and unlike yesterday - something magic happened. It functioned as it should. whatever trial you put us in seems to have found the issue.
Note even though it works it appears the cam resolution is very poor now.
Web livestreaming now works on all cams. Thank you.
Yes, web livestreaming streams but like just like Bubba Scott, resolution is terrible. The full screen image is highly pixilated.
Thank you for letting me know. Can you still send a recording or screenshot of the image quality please.
Have you tried measuring your wifi speed at the camera location with your phone?
The cam is only 20 feet from the router - my net speed is 500Mbs on a bad day.
The pixilated view is that seen on the web browser only or the app as well?
The pixilated view is only on the web app. When the android app livestreams, the label "2K Live" appears in the top left corner. The web app just shows "Live".
Just on the web app - iPhone works okay. Have a great weekend 🙂
As the OG poster the live stream issue occurs only on the web app using Chrome, Edge etc. Functions fine on Google Pixel phone app.
That is currently being investigated. I will update you as soon as possible. @BubbaScott You have a great weekend as well. Thank you.
Here is the last communication I had with support where he is L3 support and sent the issue to programming.
Sent: Thursday, May 7, 2026 11:24 AM
Subject: Re: Pro 6 not livestreaming via web
I will follow-up with Engineering regarding this issue. Hopefully we can get this resolved the soonest possible time..
Regards,
ARLO L3
Please be careful putting your personal email in a public forum.
Greetings!
I have a follow up. I have found the method I presented above to have inconsistent results. Here are other methods I have tried.
Go 2 LTE/WiFi
Firmware: 1.090.12.0_28_ac35b50
I have the Arlo app on my Android phone (Pixel 8a). The camera is connected by cellular link. The cellular link is up to date.
1. Sometimes when I attempt to play, the screen shows Connecting, flickers to live stream, and presents a recent image. I stop the attempt. When I attempt to try again, the live stream never starts.
2. Sometimes when I attempt to play, the screen shows Connecting, flickers to live stream, and presents a recent image. I stop the attempt. When I attempt to try again, the icons are presented and I press on the Orientation icon. After a few seconds, the live stream starts.
3. Sometimes I restart the camera. Method 2 above will result in a live stream but not consistently.
4. Sometimes I remove the battery for 30 seconds and place back into the camera. When I attempt to play, the live stream starts after several seconds.
Greetings!
Any updates on this issue?
I posted some work arounds but they were removed. The work arounds I cited start the streaming but they are only occasionally successful.
Thanks!
