I have several Arlo Pros between my two houses. A solar panel failed on one. I purchased a couple "Arlo compatible panels" none worked. Arlo has a panel on their website, but they dint seek it!? I purchased the arlo panel through Amazon. Arlo factory panel. It says no compatible!! Absolutely no support! And it's their product.
Message 1 of 2
884
Hi @Mark56
Do you know the Model/SKU number for the panels you purchased or have the link by chance?
Message 2 of 2
883
