  • 4 Replies
  • 1938 Views
Bob16
Model VMS4330
Tried several times but with no result - the cameras do not react on movement (initiate recording) when positioned behind window. Is that correct or do I miss some settings feature?
brh
@Bob16
That is correct, they will not work behind glass. You should probably purchase the Q Plus for that.
Brian
Bob16
Thanks! Is Q Plus compatible with the VMS4330?
brh
@Bob16
In the app they will both show, but the Q Plus does not need a Base station. It is a standalone product and works directly off the wifi.
Bear in mind, currently Arlo is having problems with the Activity Zones in the Q Plus and a couple of other cameras and is working to resolve the issue. Hopefully it will be resolved in the next couple of days.
Brian
steve_t
Master Master
Arlo, Arlo Pro, Arlo Pro 2 are designed to be positioned outside. They use PIR detection to detect motion and glass blocks IR signals. Arlo Q and Baby run off pixel detection so will work through glass
