My Cameras Are Saying Incompatible Charger
My cameras are saying incomlatible chargers detected and im using the original charger. How do I fix this
Are you using the supplied USB cable as well?
Try and remove and then refit the camera battery and then see if it works.
Is this a new system or have you successfully used the charger before?
