My Cameras Are Saying Incompatible Charger
  • 1 Reply
  • 1056 Views
Ymcvey
My cameras are saying incomlatible chargers detected and im using the original charger. How do I fix this
Streak2
Master Master
Are you using the supplied USB cable as well?
Try and remove and then refit the camera battery and then see if it works.
Is this a new system or have you successfully used the charger before?
