For some reason when I installed my cameras, only the front door will send me a notification if there is movement. My other two cameras aren’t for some reason. Any ideas as to why?
Hi Asby1,
You Can try removing and reinstalling the battery.
If that doesn't help, you can remove it from Settings, My Devices and re sync.
