My Siren On Option Has Disappeared After The Latest Update
  • 5 Replies
  • 8341 Views
rodzulu
After latest update the option to turn siren on had disappeared in mode on Arlo Pro what Arlo considers tech support is clueless that this problem even exist
Do yourself a favor avoid update unless you want to use a 5 step back spot to arm your sirens
Streak2
Master Master
You do not say what app you are using.
On my Android phone, once you log in there is a small down arrow on the main screen under Devices. Touch that and the Alarm option pops up.
5 REPLIES 5
Streak2
Master Master
rodzulu
The problem involves apple iPhones and have received no support whatsoever from Arlo tech
Nothing more than a farce as far as arlo claiming they have support for their products
The only option at this time is to revert back to an earlier version of the app
rodzulu
Apple iPhone with latest firmware
rodzulu
No solutions from tech support just little snowflake participation trophies
pc2k17
Hero
Hero
In the iPhone app there is a gray pull down bar at the top, pull it down and the alarm is there. The button was moved months ago and documented in the what's new app info.
