  • 1 Reply
  • 1606 Views
Asby1
For some reason when I installed my cameras, only the front door will send me a notification if there is movement. My other two cameras aren’t for some reason. Any ideas as to why?
ShayneS
Hi Asby1,
You Can try removing and reinstalling the battery.
If that doesn't help, you can remove it from Settings, My Devices and re sync.
