- 2
l see the siren in my device info but no longer have access to enable my siren. Has it been removed from the apps?
It was moved on the apps...
IOS ; it's a pull down bar in center screen top
Android, it's a pull down tab in center
( both from live view screen )
Just to add to the info above....... in android it's not only available in live view as a pull down tab, but it's also available when your on the devices tab as a pull down tab. It's a little tab with a down arrow on it just below the word devices.
Hello all,
I have just installed the app and put my cameras up. I have noticed that there is supposed to be an Alarm button to make the siren go off with the touch of it, but have not seen it so far. Using the knowledge base, I was told to go to the devices section and scroll all the way down and it would be there. I only see my 3 camera screen shots, and below that is a button that says "Add Device"
Can someone please point me in the right direction to be able to remotely activate this?
Helps to know which app - Android or iOS. Android now has a pull-down drawer tab near the top while iOS has a gray stripe near the top. The browser has a blue bell for the alarm.
The alarm button was moved.
In iOS is a grey pull down bar at the top on the screen.
In android it's a pull down tab in the center at the top under the devices tab or in the center of a live view video.
iPhone users don’t have this option. If buyers new this before buying I know it would hurt
sales. Netgear fix this problem.
I use to be able to turn on my siren utilizing the app on an iPhone. The function has disappeared. Can someone help?
For iOS, there's a gray stripe near the top that you use to get to the alarm, similar to what is posted in the Android thread.
As mentioned several times in this thread.......... the alarm button was moved. For iOS it is a slide down / pull down bar at the top center of the screen.
- 2
