l see the siren in my device info but no longer have access to enable my siren. Has it been removed from the apps?
top of page when Arlo opened...circled in yellow in WEB
Still appears under devices in Android ( base icon with bell )
Have you seen the small BLUE BELL icon at top of page on right side.... it was moved ( from camera box )
Top of this page? What about the blue bell icon? Why was it removed from the app. What if I want to enable it on a break in? How am I suppose to alert anybody they have trespassed on my property?
Ok I see it now. It's hidden in the in the iPhone app. There is a small line pull down. Much better place in case of accidentally enabled. Thanks.
The Blue Bell is visible on the PC IDE, but I don't see any Blue Bell in my App.
I can no longer find a way to manually turn the siren on in the app. It looks like that has been removed.
You can set it up to activate in the Rules for each camera
Ok, @Chillmiester found it. There is a tiny green bar at the top of the app page. You have to slide down eith your finger or thumb. If you did not know it was there, you would never find it. LOL
Brian
In devices. There is a greyish line. Top middle of the ios app. Scroll down.
OMG, spent an hour trying to find out where the siren icon went??
You now have to pull the thin line down on top of the devices page and it will show alarm which you can toggle on and off.
Thanks Arlo for not notifying us of this obtuse update. You owe an hour of the life back!
The hard part is finding the thin line under devices and pulling it down to reveal the alarm icon.
If your alarm goes off this is where you pull it down to turn it off. Also if you want to turn it on, someone in your house, pull down and select alarm..
Hope that helps.
I know this has already been solved, but just wanted to add some info.......
The alarm button was also moved on the android app as well, to the top of the devices page, it's a pull down tab. When I was notified by the google play store that the arlo app had an update, I went to the store and looked at the "what's new" section for the arlo app and it told me right there that the alarm button had been moved and where it was. I assume the apple store has the same info.
Moral of the story is........ I way I do it is I don't let the google store (or the apple store) automatically update my apps. I set it to not auto-update and to just notify me when an update is available. Then when I'm notified an update is available, I go into the store and always read the what's new section first to see what changes have been implemented.
I took more than hour trying to find out the siren button
Tks arlo for this !!!
It's really not that difficult. Really.
Once you know where it is, a little flick of the finger is all it takes to make it visible.
There were complaints from people because they were accidentally (for some reason) setting it off in the old position.
So................ Netgear listened to people and responded by moving it.
Now there are complaints on the new position.
I didn't realize that users accessed the siren feature so much.
@Mguerreirowrote:
For god sake
By the way. Just an FYI.
If you typed in "Siren Button" in the search the community. It would have been the first thread that came up.
Would have saved you 59 minutes and 50 seconds! LOL ![]()
Not to mention that when the version came out where they moved the siren button, in the google play store, in the what's new section, it told you the button had moved and where. I assume the apple store had similar info. Could have saved the whole 60 minutes if people would just read the what's new section before installing a new app. (turn off auto-update of apps as well)
Yes, you are correct it is very easy once you know where the line is located.. Perhaps you all could have let us know before the change, thus saving everyone allot of time and frustration.
Appreciate the reply.
@Whitefogwrote:
David,
Netgear/Arlo did tell everyone that the siren button was moved and where it was moved to. When the version came out that moved the button, the information was posted in the google play store under the "what's new" section and also posted in the apple store under the "what's new in this version" section. Turn off auto-update of apps and read the what's new section before updating any app.
The ability to set off the audible alarm is not available on my app. I can set it off from the desktop. Any suggestions on how to get this ability on the app?
Thank You
