Can you turn the siren on manually? I have pets that will set it off. I would like to do this myself after I get a notification via email or text to make sure it necessary.
Yes. In the web browser, go to the blue bell icon at the top right. In the Android app, there's a down arrow directly under the Devices tab to click and select the siren
