- 2
Since the latest iOS app update
2.6.0 I did two days ago I’ve lost the functionality of being able to Arm and Disarm my whole system by using force touch on the app. My iPhone X still allows me to force touch and select Arm or Disarm, but it will just open the app as usual, not open to mode screen and Arm or Disarm. So now I have to manually set my modes on several Arlo base stations manually. Anyone have this same problem or have a fix? I’ve tried all the normal things like force closing app, resetting iPhone, etc.
After several updates since this issue was first brought up, it still has not been resolved. This feature was working prior to 2.6.0. Seems like the Arlo "development team" and "software engineers" are too incompetent to fix what they broke.
This is downright ridiculous... I just purchased the Arlo Pro2, and to my great disapointment the Geofencing is not working at all... and as it turns out, the fallback.. using manual arm/disarm by hardpressing the app is not working either! - I cant explain to my wife and 11 year old child, that the new fancy security system i bought, requires them to "enter an app", select "mode" and then select "basestation" and then press "arm/disarm" respectivly... that is just to cumbersome to work.
How could Arlo Pro be so highly rated and recommended, when the APP and control lacks basic everyday functionality, and hyped advertised features. - and even more concerning, it seems that Arlo engineers are not addressing theese issues in a timely manner.
I like the simplicity, the desgin and the video quality... but as is, this product is close to useless, and i consider returning the kit.
Is there an update on the 3d (force press) feature for the app? It was such a conveneint feature and its really sucks that it no longer works. Please provide update status. Thank you.
3D Touch is working With 2.7 update 👍
- 2
