When I used live view, the microphone button is missing even if I already enabled it in the setting.
Any insights?????
Engineering has deployed a fix that should resolve this issue. Users may need to log out and log back in to their iOS app before they will see fix
Please let me know if you are still experiencing any issues with the microphone icon when live streaming using the Arlo iOS mobile app.
And on the Android version, mic button is still there but don't work
Apparently there is a bug and a known issue. I contacted tech support and they're working on a new release to fix it.
But yesterday when I set it up, the mic on the live view works well???
Today it disappeared????
Please fix the issue
Read some of the other threads... a new IOS app came out and it was missing... A fixed version should be along asap
Netgear is working on it
It does work fine in the PC or android app so check your system out ( it effected ONLY the new IOS app )
Well unfortunately I have the iphone and use it while i am away. doesnt help when i am traveling an do not have my PC. 😞
also you have to use chrome on the mac in order to access the mic.
hope they fix the issues.
Please fix it. Thank you.
Known issue with the last release of iOS app...soon
But the PC and android are not effected
No Mic access on arlo app on ios 10. Mic does not show in app. Does work on pc.
must be bug, wait for incoming updates.
Me too no push to talk
There are at least 4 other threads .... the MIC icon was somehow deleted in the latest iOS App release the other day for the PRO camera.
It does not effect the PC usage or Android app.
It will be fixed ASAP... but it may take a week +/- due to Apple's app process of aproval
Engineering is currently investigating this issue. I will post an update as soon as I have more information.
Users may need to log out and log back in to their iOS app before they will see fix.
you may need to delete the App and re-download it... it worked for me..
