- 2
When I used live view, the microphone button is missing even if I already enabled it in the setting.
Any insights?????
Did you try restarting the phone?
Nfial292,
Logging out from Settings > Profile should allow the microphone to show on live view. Are you using a shred login for your wifes device? If so, try unsharing the camera and then reshare.
Yes. I shared with wife and helped her setup. Got everything working but when look at LIVE from her phone the mic icon is not at the bottom of the screen.
I will try to unshare and share again.
Has there been a fix to this? I'm missing the microphone icon during live view and can't push to talk. It used to work well.
Have you tried the posted solutions? Use the menu to log out and then back in. If that doesn't fix it, try reinstalling the app.
- 2
