Since the last camera update my system goes off line after I use Live View. Tried it 3 times to make sure that was the cause (from Android app)
Try and restart the base incase there was a hickup during the update.
I did as soon as I found out there had been updates and 3 times today. Just won't use live view anymore
Try here
https://arlo.netgear.com/#/login
and see if it does the same.
What version of the app are you running?I am running 2.4.4_17405
I am really not interested in using a browser. I have the most recent app. I had no problem with going offline until the camera update.
If you don't try all the troubleshooting steps, we can't help you. Your choice.
Same here....cameras have the newest updates but go offline after a live view. Using both app and desktop computer. Certainly a little frustrating since the camera are at a 2nd house some distance away.
I've not been able to reproduce any issues with cameras after initiating a live view. Are you still experiencing this issue? Can you provide the steps you take to reproduce this?
What do you have to do to get the camera back online?
lol....well yes. all I have to do is use live view. So far it turns back on in about 5 minutes. I just don't use live view anymore.
DoriJC,
There was an issue that a small number of users were experiencing yesterday that resulted in a similar behavior. Engineering has since resolved the issue, are you still experiencing this today?
