Latest android update stops notifications on verizon S8 help?
  • 5 Replies
  • 2225 Views
DDD123
DDD123
I removed an ap called "clean master" and the notifications started working again. Thanks for your help.
5 REPLIES 5
DDD123
Sorry meant S8, tried reloading Ap, forcing stop, changing Ap settings and a million other things, cant fix it, greatly appreciate anyone's help:)
Are notifications enabled in the phone settings for the app? Under what conditions aren't you getting notifications? Do you ever get them? Battery optimization can cause delayed notifications.
DDD123
Yes, ap notifications are enabled. It used to work. I believe the Arlo update on 4/11 may have stopped it but open to checking more settings on my end.
pc2k17
Hero
Hero
Just FYI -- I have an S8 running android 8 (oreo) on ATT and notifications work fine here. Maybe it's something with your phone, or something verizon did to customize oreo for their own network (not sure of they even do that).
In android 8 the way notifications are setup are a bit different than in android 7. Make sure they are turned on for the arlo app under settings, notifications, check advanced in notifications too, and then under settings, apps make sure it says allowed for notifications under the arlo app. Also make sure notifications are enabled in the arlo app in your rule under modes.
Maybe try a reboot as well, if you haven't done that yet.
DDD123
